Duxford Incident!!!
Information, photos, dates, reviews, Red Arrows, BBMF etc
Re: Duxford Incident!!!
Postby Sooty655 » Mon Jul 11, 2011 7:47 pm
BBD appears to be intact and straightens up after being knocked sideways by the Skyraider, but the dive just gets slowly steeper and steeper.
I'm guessing damage to the elevator controls.
Postby Mayfly » Mon Jul 11, 2011 7:59 pm
There is a pic on one of the fora that shows BBD damage - will see if I can find the link
Edit here it is... thanks to FC
http://fightercontrol.co.uk/forum/viewtopic.php?f=287&t=37273&start=100
Postby Minty4371 » Mon Jul 11, 2011 8:41 pm
Video has been removed by the person who put it on.
Postby Jigsaw » Mon Jul 11, 2011 8:50 pm
Minty4371 wrote:Video has been removed by the person who put it on.
:( :( Saw that too.
Postby Mayfly » Mon Jul 11, 2011 8:53 pm
Postby Nickolas » Mon Jul 11, 2011 10:31 pm
Blimey the P51 pilot only just had enough height for the canopy to deploy.......... :-o :-o :-o
That was tooo close for comfort. :-o :-o
Postby Last Lightning » Mon Jul 11, 2011 11:02 pm
The lack of fire is interesting, did the pilot have time to switch everything off?
Whats the escape procedure?
Just because i cant help myself a shot of BBD arriving at Duxford on Friday
http://www.flickr.com/photos/last_lightning/5923321661/
Last Lightning
Postby Dan4th » Tue Jul 12, 2011 12:30 am
The "Cut" out of the underside of the
tail is where all the controls to it run.
He very basically had no tail-end controls......
Lucky that the tail wasn't severed completely!
Postby Mayfly » Tue Jul 12, 2011 9:26 am
Last Lightning wrote:The lack of fire is interesting, did the pilot have time to switch everything off?
He appears [to me] to be very level headed and didn't panic, fair play to him he wasn't that high in the first place. I have seen it said he bailed at 400ft which is pretty low, he didn't appear to panic ...guess he did all the right things.
Gaz would you like to place a link to your pic in the BBD tribute thread in aviation photography?
Edit: The clip is back on utube.... the owner says nothing sinister he was only correcting the title.
Reason: Correct speeeeling
Postby Dan4th » Tue Jul 12, 2011 5:33 pm
Just found this on Yoo-Toob, and I don't
know if "IT" is on there as I haven't watched
it all yet.
Seems to be nice quality, though........
Postby MOD » Tue Jul 12, 2011 6:49 pm
[quote="Mayfly"]
BTW This is the one I posted on page one of this topic which had since disappeared. Some more good stuff from David Taylor. Thanks for reposting Pam. :ymapplause:
EDIT re Danforth's posted video above I have a problem with this which may have something to do with my monitor.
Most of the props are either counter rotating or hardly seem to be moving. I watched the Stringbag flypast with a stationary propeller. :-o
Does anyone else have this problem? It ruined a quite good video (as did the lack of a good tripod).
Postby Hihonyr8811 » Tue Jul 12, 2011 7:34 pm
Same effect here :(
Must be the camera they used :(
Postby Hungry Haggis » Tue Jul 12, 2011 7:44 pm
good vid spoiled by the slow motion effect on the props strange as the aircraft seem to be traveling at a normal speed .Could it be frame rate ???
Postby Cluny » Tue Jul 12, 2011 7:50 pm
Deffo frame rate , compensating for shooting into the sun [had the same issue last october there] .
Anyway , the accident hasn't appeared to have put off Rob Davies [BBD's pilot] :)
http://www.itv.com/anglia/pilot-speaks-about-crash48488/
Postby Last Lightning » Tue Jul 12, 2011 10:54 pm
No not really ;) course tis done :D
Last Lightning
Postby Dan4th » Wed Jul 13, 2011 12:13 am
I didn't have a problem with the stationary
props because I chose to ignore that factor.......
Kind of like ignoring the cracks and pops on
an old LP record played on a turntable.......
The rest of it was fine with me.......
Postby Mayfly » Fri Jul 15, 2011 6:30 pm
Some photos on Flickr of BBD
Beware not a pretty sight!!
http://www.flickr.com/photos/37660802@N03/5937873485/in/set-72157624496346485/
Postby Mayfly » Sat Aug 13, 2011 4:32 pm
Postby Dan4th » Sat Aug 13, 2011 4:57 pm
Thank you, Pam........
I'm glad I got to read that, and I
wouldn't have if you hadn't posted
it up!
Postby MOD » Sat Aug 13, 2011 7:57 pm
Thanks Pam. What an uplifting story following what could have been a disastrous incident.
Postby Mayfly » Sat Aug 13, 2011 8:08 pm
I know things have moved on [parachute design] but bailing at 250ft boggles the mind a bit!
Postby Jigsaw » Sat Aug 13, 2011 8:52 pm
Thanks Pam, I thoroughly enjoyed reading that :ymapplause:
Postby Xplumberlives » Sat Aug 13, 2011 9:53 pm
Mayfly wrote:I know things have moved on [parachute design] but bailing at 250ft boggles the mind a bit!
Far better than the other option!
Postby Cluny » Sat Aug 13, 2011 9:55 pm
Mayfly wrote:Some photos on Flickr of BBD
Thats restorable , Marinell was restored from a far worse state than that .
Nice read and find :ymapplause:
Postby Mayfly » Sun Aug 14, 2011 7:23 am
Oh I know, they have restored from a Data plate before now - but it does remind me of SFs broom...
"It's only had 5 new heads and 3 new shafts"!! :))
Return to Airfields, Aircrews, Airshows
