Keeps the vids coming
320psi wrote:Just found this, it was a test run of the No2 burner back in Jan after another strip down and pipe out 'job' to fix this bunrer prob, Jim in the seat me on the tail doing the 'MK1 eye ball' check of the reheat pipe connection seal faces, this is the only way to make sure theres no leaks round there, and was SOP back in the day, a very very important check.
The SOP for the first 'drop' is to 'blip' it in so I can make sure theres no leaks, I give the thumbs up and we go again for another try, notice the second time Jim keeps it in longer and throttles it in reheat, again another important check when eyeing the guages in the cockpit, Top JPT, Top RPM, Nozzle positons need closely monitoring and noting
http://www.youtube.com/watch?v=earksmbC ... re=related
You can see from this shot that the bunrer wasnt as pronouced and powerfull, we did more work after this and basiclly tunred the 'wick' up, well thats the simple explanation anyway![]()
And this one
Fuel in first![]()
Jim ran the No2 first, and again you can see the 'lower' powered burner, very weak,,even after 2 months of fiddling
And this comparision with me in the seat running the No1 bunrer on on the same antidet run
http://www.youtube.com/watch?v=TnwXwWUP ... re=related
As you can see Jim and I work closely, always have, boucing off each other, you need two heads with Ligthnings
Interesting stuff for the like of me
Gully wrote:Missed the minute's silence and the first attempts at starting and rolled up just as the successful starting sequence was beginning, so didn't get to see Andy knawing at his knuckles! However, although I didn't do any waiting, no doubt the runs were worth waiting for! Just fantastic - well done to the whole of the LPG and thank you for keeping these beasts alive![]()
Great to get a chance for a chat afterwards - thanks Andy.
and afterwards I found the aircraft battery which had been on charge and was fully 'up'' had a cell down, this must have happened after we had done a failsafe check around lunch time, as it was fine then, Lightnings !
) with our hobby
Apologies for the focus on the last run, the camera was really struggling with the light (or lack of as it was almost pitch black). Thanks once again to the LPG for doing a great job in keeping these aircraft running - even if they don't always want to start first time.
320psi wrote:Spitfire wrote:Andy - daft question ............
Why does the top afterburner when lit look like a neat 'blowtorch' flame .. and the bottom one look much bigger but 'ragged' and sort of ... welll.. all over the place??
Is it a trick of the filming or is there some technical but stupidly easy explanation![]()
Spitfire, not a daft question at all, a very reasonable one![]()
Its the No2 engine RFCU (reheat fuel control unit) which is on the engine and to fix it we need to pull the engine, and get the engine overhauled (ummmmm) cost 15 - 25k![]()
We have been working on the No2 reheat for about 5 years on and off, pipe pulls to get at things to test them and check them, we have been though the reheat system over and over again, and each time we try a fix its another wing full of fuel to test out the 'fix' or not (£1000).
We are getting there though, as 5 years ago we had no reheat on the No2 engine at all, as this probelm isnt just one thing, Lightnings arent like that, most snags have a least 3-4 things that are playing you up, and its a matter of working though the system, canceling out the bugs, but, as we are only weekend 'fixers' and other things take our time up, sometimes the system gets another fault in mid 'fix', if you see what I mean
It can be very very very anoying
We have now decided to leave this issue, its not a problem, just the fuel pressure is weaker on the No2 burner, basiclly its works and its works safely, we are even closer, as last time out it was tending to time out and cancel its self, today John cancled the burners, so we are getting there
This imperfect burner pattern happened many times even in RAF service, they were very rarely perfect.
I can almost be sure next time out she will do something different, LIGHTNINGS ! Im afraid![]()
The old saying is very apt, 'theres aircraft and then theres Lightnings'
GC and Gary, thanks for the pics, but that one of me with the mince pies, ummmmmm, oh dear me !
They were lovely, done to a 'turn' really warm with a nice hint of avtur, see what 700 degrees C jet pipe can do, mind you its not a cheap way to warm mince pies up, but good fun, been doing that for years after a cold winters day antidet run
) don't wait
It's a shame you can't just cut and paste all your forum threads - and answers into MS Word - tweak it a bit - and you'd have a book and all the pictures to go with it .... plus MS Word would spellcheck it for you
I just type it down as I see it, and as for a book, yeh we will see one day, but who would buy it, Im sure the readership would be small, I dont think my lightning and Q shed 'wafflings' would make a book to be honest, very 'monotone' to me
320psi wrote:Spitfire, hope your daughter is making a good recovery![]()
funny who these things conspire agaisnt you in the heat of the moment![]()
Cheers
Return to Airfields, Aircrews, Airshows
