Identify the Aircraft
Re: Identify the Aircraft
Postby Dan4th » Thu Feb 19, 2009 1:08 am
Vickers Vagrant?
Vickers Vacuum?
Vickers Vegetable?
Vickers Vague?
Tail looks Vickers.....
Postby Spitfire » Thu Feb 19, 2009 1:13 am
No - not Vickers either - sorry ....... good lord I may finally have a good one..............
......... but then SBs not here yet is he :)) :D ;) :p
Postby RLN » Thu Feb 19, 2009 3:52 am
Supermarine Attacker?
Postby Xplumberlives » Thu Feb 19, 2009 8:48 am
Isn't it a HAWKER designed test vehicle?
Postby Spitfire » Thu Feb 19, 2009 11:19 am
Not Supermarine Attacker - well not by name but you could say from its origins that was sort of warm-ish and to be fair to SM with his earlier muses that it had Supermarine Swift looks I did some more research and I will add that although its not - it has also got a sort of connection - ish :D :D :D :D
Definitely not a Hawker
There's also a connection to Vulcans - in a 'type' sort of way :p
Postby Saracenman » Thu Feb 19, 2009 2:54 pm
I'm not convinced that it's even British - those roundels suggest it could be either garlic-powered or spaghetti-fuelled - what say ye oh Oral Emitter of Flame :D
Postby Spitfire » Thu Feb 19, 2009 2:58 pm
It is actually fuelled entirely by bacon & eggs with fright bread - no garlic or spaghetti has got anywhere near it to my knowledge and belief :D :p
Postby Saracenman » Thu Feb 19, 2009 3:15 pm
Handley Page HP88? :D
Postby Xplumberlives » Thu Feb 19, 2009 3:28 pm
Also designated YB2
Postby Spitfire » Thu Feb 19, 2009 3:56 pm
Correct - and it was interesting that it was a British research aircraft, built to test the aerodynamics of the Handley Page Victor design and was essentially a scaled-down version of that aircraft. There are elements of the Supermarine Attacker and Swift in it i.e. the wing roots .....but look at that interesting wing shape.
Only one was made and it crashed due to a tailplane servo control system failure.
Back to you SM - of course you don't know ANY aircarft at all and you're just guessing =)) (as if :D )
Postby Saracenman » Thu Feb 19, 2009 4:07 pm
LOVELY shape those wings have :x
Spitfire, that was down to much ~x( and dedicated research! a huge slice of luck too - your last clue with the loose Vulcan connection, i fortunately plumped straight for the HP Victor before anything else. i still know very few aeroplanes! :((
well, I'll now have to try and remember which dastardly fiendish aeroplane i found the other night, in case of such a win............erm............. =))
edit: here you go then :ymdevil:
Postby Spitfire » Thu Feb 19, 2009 4:26 pm
So that would be the Convair XB-36 then :ymsmug: :ymsmug: :ymsmug:
So very dastardly and fiendish it didn't need much searching - sorry :D ;)
Postby Xplumberlives » Thu Feb 19, 2009 4:27 pm
I wonder how many miles to the gallon it got cross country?
Postby Saracenman » Thu Feb 19, 2009 6:30 pm
bloodyhell - i KNEW i should've used the uber-sneaky one instead :((
over to you Spitfire (at least you beat SB to it though! =)) )
Postby Stevieboy » Thu Feb 19, 2009 7:15 pm
Having seen some of SM's take offs in FS I guess that he's investigating having tracks fitted to his VC-10 model. =)) :o)
Postby Spitfire » Thu Feb 19, 2009 8:14 pm
Taking my life in my hands - giving you the whole image :D
Postby Dan4th » Thu Feb 19, 2009 8:19 pm
Looks German.......
Has enough guns on it!
Postby Spitfire » Thu Feb 19, 2009 8:22 pm
Ok - I'll give you German - even after I psp'd all the markings off :(( [-(
Postby Xplumberlives » Thu Feb 19, 2009 8:24 pm
It's the well known;
Dornier/Heinkel/Messersmidt/Feisler!
Postby Spitfire » Thu Feb 19, 2009 8:29 pm
Xplumberlives wrote:It's the well known;
MMmmmm now I'm on the horns of a dimella - do I say it IS one of those or it ISN'T one of those ;) :p
Or do I say nothing :ymdevil:
Postby Dan4th » Thu Feb 19, 2009 8:49 pm
I would personally advise you say nothing.......
Name, Rank, Serial Number is all that's req'd.
Postby Xplumberlives » Thu Feb 19, 2009 8:58 pm
Heinkel He 277?
Postby Mackrick » Thu Feb 19, 2009 9:10 pm
Thought the 277 was 4 engined not 2 .
Heinkel 274 ?
Postby Spitfire » Thu Feb 19, 2009 9:41 pm
Nope & Nope to the Heinkel guesses :D .... now if I can just keep SB away for a little bit longer ;) :))
Postby Stevieboy » Thu Feb 19, 2009 9:50 pm
Users browsing this forum: No registered users and 19 guests
