More Spitfire Art - WIP
Re: More Spitfire Art - WIP
Postby MOD » Mon Jan 23, 2012 7:34 pm
Wow ... is my considered opinion.. :ymapplause:
However I do see exactly what Sooty means. That Spit does not appear to be flying as though it was the one that initially scored the hit on the 109. Could you just lose the rear two puffs of smoke? And perhaps but on a bit of left aileron/rudder to show he is/was tracking the 109 rather than flying straight at it amidships?
Nit-picking really... ;)
Postby ActionArt » Mon Jan 23, 2012 7:57 pm
I see what you mean. As the pilot described it, he fired and hit the 109 with a long canon shot and then turned to avoid getting in front of the rest of the 109s (banking hard right and then hard left later). The plan was to show he had a few strikes and then banked right (not wanting to be the target of other 109s behind) but I can see that's not really apparent from what I have here. I'll have to think that through a bit. Maybe just losing those two smoke puffs may do it as you say.
ActionArt
Postby Mayfly » Mon Jan 23, 2012 8:46 pm
Len would I be right in thinking you paint in layers?
Postby Jigsaw » Mon Jan 23, 2012 8:57 pm
Mayfly wrote:Len would I be right in thinking you paint in layers?
Undies, Vest, smock?
I think it is brilliant :D
Postby ActionArt » Mon Jan 23, 2012 9:03 pm
:)) Add wool jacket and bear skin parka for this country!
But yes, to the actual question. I do whatever I can in layers so I can change things easier later (like this smoke issue for instance). Some things just can't be done in layers but usually, yes.
ActionArt
Postby Dan4th » Mon Jan 23, 2012 9:08 pm
I'm of the opinion that a little artistic
license is not a bad thing.....
I'm also of the opinion that you can
over-think something to death...
Postby Mayfly » Mon Jan 23, 2012 9:19 pm
jiggy = pillock!!! :))
That's what I guessed - thanks
Postby Xplumberlives » Mon Jan 23, 2012 9:49 pm
Looking forward to seeing the changes you make Len, from your description of what was actually happening at the time it makes sense to me! ;)
Postby ActionArt » Fri Jan 27, 2012 4:26 pm
Here's some updates. I tried two variations with the smoke, let me know which you like better.
Here's some larger ones. I took some blur off the 109, added a bit to the Spitfire.
I don't want to over do it on the Spitfire because the viewer/camera is traveling with the Spitfire so the relative speed would be almost the same. A little helps it blend in nicely though.
I'll be seeing the pilot soon so I'll ask him how much wear and dirt it should have. It was almost a new aircraft so I don't think it should have too much. I'll check...
http://www.actionart.ca/ForumPics/DougT10.jpg
http://www.actionart.ca/ForumPics/DougT10c1.jpg
http://www.actionart.ca/ForumPics/DougT10c2.jpg
ActionArt
Postby Mayfly » Fri Jan 27, 2012 4:54 pm
Not sure if it' was intentional or the effect of removing a layer but I definitely prefer the additional detail on the ME109 cockpit of the revised edition and in fact I prefer the one with less smoke. :ymapplause: :ymapplause: :ymapplause:
Postby Xplumberlives » Fri Jan 27, 2012 5:10 pm
Len
If you go for the version with less smoke it would appear that the German Pilot was VERY quick at jettisoning his canopy. But with the extra, earlier puff of smoke it at least looks as though he took a couple of seconds to consider bailing out!
Dave
Postby RLN » Fri Jan 27, 2012 5:23 pm
I'd go with more smoke.
Postby Xplumberlives » Fri Jan 27, 2012 5:31 pm
RLN wrote:I'd go with more smoke.
Cremation for you then! :p
Postby ActionArt » Fri Jan 27, 2012 5:41 pm
Thanks everyone! I'll think on it for a bit and then I'll have to make up my mind :)
Doug said the canopy flew off the same instant it was hit. Either the canon shell blew it off or the pilot was already reaching for the handle when the shells hit. But the average viewer doesn't know that up front so I have to consider that...
ActionArt
Postby Gaz » Fri Jan 27, 2012 6:57 pm
It's almost there Len!
Looking forward to the finished article!
Postby Dan4th » Fri Jan 27, 2012 7:01 pm
I'm thinking............
I like seeing the ME better defined......
I like more smoke...........
The Spit might be new, but couldn't it
have some oil and exhaust stains?
It's just too "Shiney"!
These aircraft didn't stay "New" very long!
I still think this is a Great Moment in Time!
Postby Gaz » Fri Jan 27, 2012 8:02 pm
Dan4th wrote:I have no opinion re: blurring or lack of, although
what we're looking at here is a frozen moment in
time, so it really doesn't matter.......
Dan4th wrote:I'm thinking............
Make up your mind!!
Only playing, Danf ;)
Postby Xplumberlives » Fri Jan 27, 2012 8:56 pm
Well I wanted a less blurred Me 109 from the start! ;)
Postby MOD » Fri Jan 27, 2012 10:38 pm
The second one does it for me Len. ;)
Postby ActionArt » Sat Jan 28, 2012 3:29 pm
That you very much everyone! If anyone has a few nice clear color images of Spitfires with wear during wartime feel free to post :) I have a couple but more is better.
I'll be visiting the pilot probably next weekend so after that I'll give it one more go and it'll be done.
Then on to Don Laubman's Spitfire. He's been waiting patiently.
ActionArt
Postby ActionArt » Thu Mar 08, 2012 6:49 pm
Well, this one is finally done and off to the print shop! Many thanks to everyone here!
Here's a high-res: http://www.actionart.ca/images/SilverLiningWeb.jpg
ActionArt
Postby Gaz » Thu Mar 08, 2012 8:52 pm
BRILLIANT!!!
Postby MOD » Thu Mar 08, 2012 9:01 pm
Stunning. :ymapplause: :ymapplause: :ymapplause:
Len, when you sell one of these pictures do you provide a 'potted history' of the action and who the protagonists are/were?
Mod
PS:
I just caught myself staring at the blank wall behind my PC monitor as I sit here typing this. Mmmmm :-? . I wonder if Mrs Mod and the girls fancy chipping in together for an early 65th birthday present :D
What I really like about this picture, as well as the dynamics of the subject, is the widescreen, almost landscape, aspect ratio. Or am I gibbering again :(
Postby Dan4th » Thu Mar 08, 2012 9:06 pm
Well, I think it's pretty damned good!
I'm happy we might have had some tiny
little part in it, and let's hope it SELLS!!!!!!
If the right people see it, it WILL!
Postby ActionArt » Thu Mar 08, 2012 9:17 pm
MOD wrote:Stunning. :ymapplause: :ymapplause: :ymapplause:
Mod
PS:
Yes, I definitely provide all the info for the people involved. I'm going to visit the pilot this weekend to get him to sign the original.
A very special deal to anyone from here of course if you'd like one :)
I ended up changing the aspect ratio at the last minute, I'm glad you like it.
Thanks everyone! Now to start on Don Laubman's.
ActionArt
Users browsing this forum: No registered users and 22 guests
