What is your favorite military aircraft?
Re: What is your favorite military aircraft?
Postby Mayfly » Fri Nov 27, 2009 5:14 pm
:ymapplause: ..... theres just so many good ones around
Postby Xplumberlives » Fri Nov 27, 2009 5:16 pm
Mayfly wrote::ymapplause: ..... theres just so many good ones around
I bet you say that to all the boys!!!! ;) :p
Re: What is your favourite military aircraft?
Postby Mayfly » Fri Nov 27, 2009 5:20 pm
[-x Told you before XP I'm very choosy!!!!
Postby Xplumberlives » Fri Nov 27, 2009 5:21 pm
:-o =)) =)) =)) =))
Postby Ta152c » Tue Dec 01, 2009 12:41 pm
IL-2 Stormovik. Best attack aircraft of WW2, not the lame duck as often portrayed. Responsible for destroying vast numbers of enemy materiel, plentiful and once mastered, quite agile. Although shot down by the thousands, high production numbers anyway. Once pilot training improved with greater tactical awareness, the results were devastating. No wonder the German soldier called it 'Der Schwartze Tod'!
Ta152c
Postby Gaz » Tue Dec 01, 2009 4:28 pm
Well if things had gone the way they should have gone, I'd be saying the TSR, but, I suppose I'll have to settle for a Lightning, I'm not too fussed which one, they were all awesome!
Postby Canberra Man » Thu Jan 07, 2010 9:21 pm
My favourite aircraft has to be the two I worked on in the RAF as electrcal fitter. They were first the Lincoln, a big beautiful brute. I had many flights in them and always flew in the rear turret. One had a good view of where you had been and if you wanted to see where you were going, the turret could be turned fully left or right and you could look down the fuselage to the front. But in my mind, the Canberra was the best, I cadged as many trips as as I could. I will be posting back in "Tales from the RAF". I havn't posted for a while, Ive put Windows 7 on my computer and lost all "My Favourites" in the process, if everybody does that I might get all my addresses back.
Ken
Canberra Man
Also Known As: Sparky
Postby Dan4th » Thu Jan 07, 2010 10:53 pm
Anything you care to throw our way is more
than welcome, Ken.
And actually, there's even some pretty good
free computer advice available on here if you
should need it.
Some of the OTHER advice I'm not so sure of....
But anyhow, it's good to see you back. Glad we
didn't lose you.
Users browsing this forum: No registered users and 42 guests
