Wet 'n Wokka
Re: Wet 'n Wokka
Postby Mayfly » Thu Nov 26, 2009 12:43 pm
Great bit of kit
but
Bravo November Rules \:D/ \:D/ \:D/
Re: Wet 'n Wokka
Postby Spitfire » Thu Nov 26, 2009 1:39 pm
All you military types on here - question - maybe a stupid question..... ;)
But in a desert scenario what specifically is done to the engines and running gear (cyclic heads and gearboxes) to stop dust ingestion .....for sometimes on these videos I see the Wokka disappear into a huge cloud of dust and that can't be good for mechanical bits sand being VERY abrasive :p :D
Exposed grease can't be good either as sand will stick to that like the proverbial and form a lovely carborundum grinding effect to ball races and bearings :D
Re: Wet 'n Wokka
Postby Thumper » Thu Nov 26, 2009 2:38 pm
Re: Wet 'n Wokka
Postby Spitfire » Thu Nov 26, 2009 8:59 pm
Thumper wrote:Interesting story on it here:
http://www.thefreelibrary.com/U.S.+Army ... 0129259276
AHA - thanks for that - so PALL makes millions for keeping things clean :D :D
Seems to work too :p
Re: Wet 'n Wokka
Postby Pujgnie » Fri Nov 27, 2009 5:49 pm
Wokka pushed to the limits - with sad outcome :(
Brave bit of flying by all involved :ymapplause:
Re: Wet 'n Wokka
Postby Xplumberlives » Fri Nov 27, 2009 6:35 pm
Shame the embedding is disabled!
Re: Wet 'n Wokka
Postby Mayfly » Fri Nov 27, 2009 6:39 pm
Thanks Mr Knees will watch it later when I have more time
Re: Wet 'n Wokka
Postby MadNaddy » Fri Nov 27, 2009 10:08 pm
Thanks for that Pujgnie....
Sad outcome indeed but some amazing flying. Can't believe they left the apache behind!
Re: Wet 'n Wokka
Postby Old Rigger » Sat Nov 28, 2009 11:27 am
Spitfire, added to the EAPS described in the link, we also had a pressure washer loaded on a unimog which we used to jet wash the aircraft and after we wondered why one of ours that had an acceptable leak from the forward gearbox which coated the sliding tube had less problems than the others we decided to wipe down the others with a thin film of oil, did it when we were in Turkey during the relief operation there as well, much to the 'shock and horror' of the crews from the pristine clean shiney fleet of 7 Sqn.
As an aside the EAPS was brill at night, as the sand was extracted as it was like seeing what you see when you grind metal on a grindstone, a nice glowing ring with shower of sparks out of the exhaust.
Users browsing this forum: No registered users and 24 guests
