Pujgnie wrote:603 is in pitiful condition - moss, grime algae etc... How come she has gotten into this state ? Have her owners deserted her ? Painful to see any Vulcan left to rust and be neglected like that. IMO
How long does she have left on this planet - before she is carved up by a 'heartless' scrap merchant ?
Sooty655 wrote:
The Woodford factory will close when the current Nimrod project is finished - current best guess is 2012.
Pujgnie wrote:Are you guys going to be there when she gets cut up?
Xplumberlives wrote:Where have you got it stashed now?
Ducati Boy wrote:Oh by the way, I assume H&S rules were applied and steps taken to secure the airframe from moving, before any work involving possible weight transfer,. This is because the undercarriage strut and locking system had been removed by "someone" in the past (definitely NOT TVOC), leaving the aircraft somewhat precariously balanced on her legs which, seeing as they retract forward, could have collapsed with any rearward shift of weight.
Well I guess "someone" must have pumped her up since we saw her then. Well done, pity she can't be kept, but I bet with the potential value of Woodford for building land is probably zillions so she is definitely a gonner.Sooty655 wrote:Ducati Boy wrote:Oh by the way, I assume H&S rules were applied and steps taken to secure the airframe from moving, before any work involving possible weight transfer,. This is because the undercarriage strut and locking system had been removed by "someone" in the past (definitely NOT TVOC), leaving the aircraft somewhat precariously balanced on her legs which, seeing as they retract forward, could have collapsed with any rearward shift of weight.
Undercarriage ground locks were and are in place and secure, and all CofG transfer was forward. The main gear suspension (liquid springs) are fully operational.
Ducati Boy wrote:Well I guess "someone" must have pumped her up since we saw her then. Well done, pity she can't be kept, but I bet with the potential value of Woodford for building land is probably zillions so she is definitely a gonner.
Sooty655 wrote:
We got the impression there is a good chance the cockpit will survive.![]()
(maybe even a main bogey undercarriage too - that wouldn't go amiss in any museum ?)
Also it would be easy to power up via the sockets at the PB.
Ducati Boy wrote:I have a massive wish list of stuff to save for 558 including several instruments which are zero stock or very rare, but we are told they cannot be touched. That makes me think the cockpit section may well be already allocated. If it is I hope they have the sense to cut it behind the pressure bulkhead and make it easy to secure and keep dry.
Ducati Boy wrote:I have a massive wish list of stuff to save for 558 including several instruments which are zero stock or very rare, but we are told they cannot be touched. That makes me think the cockpit section may well be already allocated. If it is I hope they have the sense to cut it behind the pressure bulkhead and make it easy to secure and keep dry.Also it would be easy to power up via the sockets at the PB.
Ramshornvortex wrote:Nos 2 and 3 zero-houred 301s safely dropped out of '603
The engine bay seems cavernous without an Olympus in it!
A view you don't see too often! We did replace the blanks at both ends before we left Woodford...
No 3 jet pipe took a bit of persuasion to move back sufficiently to clear the end of the engine. Cue the MaPS 'strongest man in the world'![]()
Bovril wrote:
Xplumberlives wrote:Bovril wrote:
Blimey, that lorry must potentially be the FASTEST in the world!
Users browsing this forum: No registered users and 29 guests
