Postby Richw_82 » Tue Feb 05, 2013 11:23 am
Cumulative flying hours stand at 15,483.
The spar booms that are fitted are near their limit, with slightly over 80 hours left when WR963 was delivered to Coventry. There are also several areas of concern regarding intersecting bolt holes, and cracking between them which means a replacement is the only way forward for a lasting return to flight rather than a brief one, and currently the only way open to us with the CAA. Having said that - the replacement would be value for money as on a similar annual usage to the BBMF Lancaster (or less...) a career of another 40 years is then a possibility.
I am assured the new website is coming, its just taking a little longer than anticipated. I don't have any hand in it, so I've been asking the same question.
I will be there this Saturday! I'm still annoyed I missed a couple when Derbyshire turned into Siberia a couple of weeks ago and I couldn't get out.
Update - Please welcome G - SKTN to the UK Register. :D
Postby MOD » Tue Feb 05, 2013 11:40 am
:ymapplause: :ymapplause: :ymapplause: B-)
Postby Mackrick » Tue Feb 05, 2013 12:25 pm
Congratulations Rich
Keep the updates coming......
http://www.caa.co.uk/application.aspx?catid=60&pagetype=65&appid=1&mode=detailnosummary&fullregmark=SKTN
Postby Xplumberlives » Tue Feb 05, 2013 5:23 pm
:ymapplause: WONDERFUL! :ymapplause:
Postby RLN » Tue Feb 05, 2013 5:44 pm
Good news. Look forward to seeing her at RIAT. :ymapplause:
Postby Jigsaw » Tue Feb 05, 2013 6:25 pm
That is fantastic :ymapplause: :ymapplause:
(I still think she should have been registered as G-ROWL though) :p
Postby Richw_82 » Tue Feb 05, 2013 7:00 pm
Cheers all!
G-ROWL was already taken, as were a few other combinations. SKTN is the four letter manufacturers code on the data plates and was available, so we went for that instead.
Postby Hungry Haggis » Tue Feb 05, 2013 7:02 pm
Unfortunatly seems to have been taken already
http://www.caa.co.uk/application.aspx?c ... gmark=ROWL
Postby Sploosher » Tue Feb 05, 2013 10:15 pm
Great news indeed about her Civil reg code................. \:D/
another step nearer to gracing the skies................ :ymapplause:
Postby Richw_82 » Sat Feb 16, 2013 8:09 pm
Hi all,
Following a good long trip south in the van, WR963 now has a mid upper turret cupola, thanks to a top bloke who purchased it then donated it to the aircraft. Chris Wilson - thank you!
Photos -
Kind regards,
Postby Mackrick » Sat Feb 16, 2013 8:43 pm
Thanks for the update Rich :ymapplause:
Postby Xplumberlives » Sun Feb 17, 2013 9:34 am
Where did he find a turret? :-o
:ymapplause: Nice work fella! :ymapplause:
Postby Richw_82 » Wed Feb 27, 2013 6:44 pm
23rd Feb
For those that couldn't be there...
The object of Saturday was to remove the front propeller from No 2 engine, fit some new bearing parts, fit the translation unit, and then re-fit the propeller again. With all the upheavals at Coventry, yet again this was all going to be done without the assistance of any kind of crane. Luckily we had a visit by Jocelyn, with a very capable friend along with her, and he dived right into the thick of things helping us greatly .
With a reasonable amount of manpower, this is not too difficult as despite its size and awkwardness the propeller is not too heavy, and with the aid of a couple of platforms it was soon safely off the engine. Then it was swiftly on to fitting the intershaft bearing inner race and retaining nut.
This is a part we've been waiting for for a while, as for some unknown reason the No 2 now fitted was the only one in our store missing this item, and at the time it wasn't noticed. Its just that rare for them to be missing! Chasing up and down the country for a suitable tool to remove one from another engine finally paid off, with one of our friends in Carlisle coming up with the necessary parts. This has taken a few months longer than hoped.
With that in place, the translation unit is next. This is an oil filled double bearing, produced by Martin Baker, and transfers the pitch of the front propeller to the back propeller, using several rack bolts. The loss of a rack bolt and subsequent break up of one of these was a contributary factor in the loss of the SAAF Shackleton in the Sahara in 1994.
Then it was back up with the front prop, and fitting the pitch change mechanism itself.
At the end of the day we were all very cold, but happy that we are six split pins and a small amount of wire locking away from running the No 2 engine.
The aim is to have WR963 taxying this year, while we raise funds and organise getting her a roof over her head - and if No 2 behaves in the next few days, the goal of taxying is not far off.
Postby Jigsaw » Wed Feb 27, 2013 7:34 pm
Bloody brilliant :ymapplause: :D
Postby Dan4th » Wed Feb 27, 2013 9:27 pm
Won't that be a Great Day!!!!!!!!!!!!!
Nice to see all the hard work and progress :ymapplause:
Postby Mackrick » Thu Feb 28, 2013 9:20 pm
Thanks for the update Rich.... All 4 running on the next ground run I hope :ymapplause:
Postby Richw_82 » Fri Mar 01, 2013 10:00 am
The plan is to try and run No 2 on its own tomorrow, then if it goes well all four next week.
Once No 2 is running there's several things we need to check, which are best done without the others running - checking for leaks, temperatures and pressures all correct, generator, pneumatics, etc.
Postby Richw_82 » Sat Mar 02, 2013 9:01 pm
It lives. :D
Thanks to all that have helped make it happen.
Postby Sploosher » Sat Mar 02, 2013 10:27 pm
Richw_82 wrote:It lives. :D
yesssssssssssssssssssssss, I definately think its time for another visit \:D/
well done to you and all your guys Rich......... :ymapplause: another step nearer gracing the skies again........ \:D/ \:D/
Postby Mackrick » Sun Mar 03, 2013 4:56 pm
Nice work Rich :ymapplause:
Postby Gaz » Sun Mar 03, 2013 6:26 pm
VERY well done!!
Postby Richw_82 » Mon Mar 04, 2013 10:16 am
Thanks guys.
Saturday 9th March will see all four running, as previously promised. Following that there will be a few weeks sorting brakes and other systems out.
In the background, the next bits of paper to send to the CAA are being arranged.
Postby Jigsaw » Mon Mar 04, 2013 11:07 am
Great stuff. Congrats to you all :ymapplause:
Postby Richw_82 » Sat Mar 09, 2013 6:22 pm
Taken earlier today by one of our visitors. Full 'growl'.
Postby Cluny » Sat Mar 09, 2013 7:17 pm
Great news , wish I could of been there :)
Users browsing this forum: No registered users and 25 guests
