Airfix Vulcan B mk2
Airfix Vulcan B mk2
Postby Pujgnie » Mon Dec 29, 2008 7:48 pm
Already have one as 607 variant.. built in 95. Sadly a bit brittle nowadays.
Have 2 new ones to build.. first one will her ladyship!! - that means lopping off the TFR blister :)
Re: Airfix Vulcan B mk2
Postby Spitfire » Mon Dec 29, 2008 10:53 pm
Yes I have a 1/72nd one waiting to be built - I will, of course, be making it XH558 too... just waiting for the spirit to move me ;) :p
Postby Cluny » Mon Dec 29, 2008 11:13 pm
If you want the proper 200 series jet pipes [the kit has 300 series jet pipes] when modeling 558 , these guys do a conversion kit for it [1/72 post war RAF RN section] ;)
http://www.djparkins.clara.net/fltpath/fpmaster.htm
Postby Spitfire » Tue Dec 30, 2008 12:41 am
Cluny wrote:If you want the proper 200 series jet pipes [the kit has 300 series jet pipes] when modeling 558 , these guys do a conversion kit for it [1/72 post war RAF RN section] ;)
How cool is that -thanks Cluny - getting one of those B2 sets :D
Postby Pujgnie » Wed Jan 21, 2009 12:13 am
Thanks for the link :)
The ugly horizontal jointing seam is still evident I see. I guess much sanding, filler/buffing and TLC will be required prior to painting. On a point of detail.... don't use the 558 City of Lincoln transfer - it's the wrong colour..( use the 607 one - with the white background).
NB - DO NOT forget to weight the nose section before you join the 2 halves !!! ;)
Just to update this - found a link to the traits of this kit :
http://www.modelingmadness.com/reviews/mod/kolvulcan.htm
Updated 20 Jan: (Seems I can not add to the thread until it is replied to... odd) Hey Ho
Have just recieved the B2 Detail set. There's a lot in there... some worthy, some not. Cockpit detail for instance - Why ? :)) Fiddly is not the word, it's wafer thin and very bendy.. and paint is not too happy to adhere to a gold metallic item.
Qwik tip... apply a blast of undercoat and sealant before painting. (Not sure if the canopy framing is going to align on this... time will tell). Best bit... the proper 200 series jet pipes and the alloy wheel rims :)
All in all a worthy edition.. but be warned it is fiddly - and you need to chop/saw bits off the original if you making 558.
Postby IanM » Wed Jan 21, 2009 1:13 pm
What are the differences in the jetpipes???? They all look the same to me.
Postby Bovril » Wed Jan 21, 2009 5:50 pm
basically ... the angle of the pipes away from the rudder, longer and tapper to a smaller opening i think
IanM wrote:What are the differences in the jetpipes???? They all look the same to me.
Postby Pujgnie » Wed Jan 21, 2009 7:31 pm
The Airfix model is based on the 300 series engines and jet pipes.
If anyone is building the 558 version - the 200 series jet pipes are required for accuracy. Bovril is correct in his thoughts :)
Postby Bovril » Wed Jan 21, 2009 10:28 pm
655's mighy 300 Series engines :D
558's not quite as powerful 200 Series ;)
hope you can see the diferrences
Users browsing this forum: No registered users and 16 guests
