Qantas Flight De-Compression
Postby Thumper » Tue Jan 25, 2011 11:01 pm
Reason: Qantas spelling corrected
Re: Qantas Flight De-Compression
Postby Gaz » Tue Jan 25, 2011 11:25 pm
I bet that was scary!
Postby Thumper » Tue Jan 25, 2011 11:31 pm
Thanks for editing it Sooty but you managed to delete someone's comment! Jiggy's I think =))
Postby Sooty655 » Thu Jan 27, 2011 3:00 pm
In their usual fashion, PPRuNe have rapidly moved the story from News to Spectators Balcony, on the basis that the aircraft was never in any real trouble and it is all just hysterical newspaper reporting.
It seems to me that from the passengers point of view, a decompression sufficient to drop the oxygen masks followed by a rapid descent of 26,000 feet is going to get your attention and should be considered an incident.
The newspapers and other media may be overdoing it with words like "plummet" and "suddenly dropped", but the event is certainly worth reporting.
Postby Gaz » Thu Jan 27, 2011 3:06 pm
I was on a flight back from Florida, a few years ago. The aircraft had landed and was taxiing to its stand. For some reason, the O2 masks deployed. Even though we were on the ground, some people panicked.
Postby Thumper » Thu Jan 27, 2011 3:26 pm
With things like this the media will always go overboard with words like "plummet" and "dropped out of the sky" as it gets hits.
The BBC news website is unfortunately getting more and more like this with ridiculous headlines that are terribly misleading.
Either way, I felt it was worth reporting as there was a fault (some say 2 faults) with the air conditioning unit which could I suppose have led to the type being grounded for investigation. That is personally why I thought it was news worthy and a descent from 26,000ft to 10,000ft is a big "drop" and despite being in a controlled manner I am sure it was quite a scary experience.
Postby Gaz » Thu Jan 27, 2011 4:40 pm
It is newsworthy.
The only reason I made fun of it (Now moderated, long story, water under the bridge), is because I make fun of everything and will continue to do so ;)
Postby Thumper » Thu Jan 27, 2011 5:27 pm
I'm too slow to keep up with the rate this thread has been moderated at :))
Users browsing this forum: No registered users and 16 guests
