CH5 7:30pm - Extreme Airports
Postby Thumper » Thu Oct 14, 2010 5:11 pm
Channel Five tonight, Worlds Most Extreme Airports.
I am guessing St. Maartan, Kai Tak and St. Barts will feature but will be an interesting watch with some good footage! :D
Re: CH5 7:30pm - Extreme Airports
Postby Xplumberlives » Thu Oct 14, 2010 5:13 pm
Already listed under the up and coming aviation programme thread! :p
Postby RLN » Thu Oct 14, 2010 5:22 pm
Reminder set.
Postby Dickon » Thu Oct 14, 2010 7:37 pm
Watching now.............
Dickon
Postby Thumper » Thu Oct 14, 2010 10:00 pm
Xplumberlives wrote:Already listed under the up and coming aviation programme thread! :p
Well you should've deleted it then rather than moan about it!
Postby Xplumberlives » Fri Oct 15, 2010 7:55 am
I don't have the power to delete, that rests with the MODs! :p
Last edited by Xplumberlives on Fri Oct 15, 2010 11:19 am, edited 1 time in total.
Postby Thumper » Fri Oct 15, 2010 11:17 am
And you're just a rebel Rocker :))
Postby Old Rigger » Sun Oct 17, 2010 2:47 pm
Well enjoyed this and can confirm the Gibralter bit as a Nimrod I was passenger on nearly wiped itself out trying to land with all the weather against it, we ended up going to Faro in Portugal with low fuel as Lisbon would not let us land. Also there was the possibility of being shot at when taking off from the harbour end if you did not climb and turn sharp enough after lift off.
