Asymmetric approach
Asymmetric approach
Postby Hihonyr8811 » Sun Feb 21, 2010 10:19 pm
So first of all, I assume it's this?
Secondly, In the last week two people have asked me (my mum and someone on Youtube) why aircraft do this and I think I know but it's proved to me that actually, I don't really understand it :ymblushing: =)) , but I'd like someone to please take a moment to explain it better than me :D
Thirdly, can I copy any answers to YT and to tell mum :D pretty please.
Re: Asymmetric approach
Postby Old Rigger » Sun Feb 21, 2010 10:59 pm
Hi Helen, I hope the link below will give you some idea, also there are instances of asymmetric flaps that cause a similar effect.
http://www.cast-safety.org/pdf/5_asymmetric_flight.pdf
Thought I would add this from you tube, have not watched it all but it is supposed to give and idea from inside the plane.
edited to add youtube link - SF
Postby Hihonyr8811 » Sun Feb 21, 2010 11:28 pm
That's pretty much exactly what I was after thanks :D
I assume the basics apply to a Tornado as well?
Postby Old Rigger » Sun Feb 21, 2010 11:47 pm
basically yes, any multi engine aircraft can have asymmetric thrust, in the case of the Tornado in the picture this is due to different thrust between the two engines as seen in your photo, the left hand engine has no reheat engaged so the aircraft will be trying to turn to the left (more thrust on the right causing aircraft to yaw to left) and if you look carefully you will notice the rudder is off to the right to compensate.
Postby Hihonyr8811 » Sun Feb 21, 2010 11:55 pm
I love learning new things :D
Thanks a lot :)
Postby Dan4th » Mon Feb 22, 2010 12:17 am
Don't you just LUV the word "THRUST"?
I know EYE do!
Postby Hihonyr8811 » Mon Feb 22, 2010 12:20 am
:D =)) =))
Users browsing this forum: No registered users and 75 guests
