Identify the Aircraft
Re: Identify the Aircraft
Postby Xplumberlives » Sun Apr 12, 2009 4:24 pm
So, longshot I know but is it the not very well known Australian Cattle Mover?
Postby Saracenman » Sun Apr 12, 2009 4:26 pm
:ymapplause: Australian indeed - but not necessarily designed for transporting cattle - it may have been used for that task though!
Postby Xplumberlives » Sun Apr 12, 2009 4:35 pm
Transair PL12 AIRTRUCK
Postby Saracenman » Sun Apr 12, 2009 4:40 pm
:ymapplause:
correct!
beautiful machine! =))
actually - that pic looks as if that a/c DID undertake some crop-spraying!
your turn XPL
Postby Xplumberlives » Sun Apr 12, 2009 4:49 pm
I will start looking for something FIENDISH and will post soon!
Postby Dan4th » Sun Apr 12, 2009 5:23 pm
Whoever designed that aircraft was
obviously under the influence of LSD!
Postby Xplumberlives » Sun Apr 12, 2009 5:27 pm
Dan4th wrote:Whoever designed that aircraft was
That's good, coming from across the pond!
Postby Ducati Boy » Sun Apr 12, 2009 10:29 pm
It looks like a load of other aircraft parts from a scrap yard, hideous :-o :D
Ducati Boy
Also Known As: Biker Boy
Postby Xplumberlives » Mon Apr 13, 2009 2:56 pm
So,
What is this then, one of my favourites!
Postby Saracenman » Mon Apr 13, 2009 3:01 pm
it has a Frog look to it - Mirage of some sort?
Postby Xplumberlives » Mon Apr 13, 2009 3:03 pm
Not sure that FROG made a kit of this aircraft!
Postby Saracenman » Mon Apr 13, 2009 3:04 pm
eh? =))
Postby Xplumberlives » Mon Apr 13, 2009 3:07 pm
FROG
British plastic kit manufacturer of the 60s and 70s! :p
Postby Saracenman » Mon Apr 13, 2009 3:11 pm
:p you know what i meant!
so what's the answer then? is it FRENCH? a Mirage?
Postby Stevieboy » Mon Apr 13, 2009 3:16 pm
Xplumberlives wrote:Not sure that FROG made a kit of this aircraft!
If not FROG how about Heller? :p
Postby Xplumberlives » Mon Apr 13, 2009 3:21 pm
Heller might have
Postby Saracenman » Mon Apr 13, 2009 5:30 pm
is it this Dassault-Breguet Mirage IV?
Postby Prometheus » Mon Apr 13, 2009 5:40 pm
Looks like you could be right SM :ymapplause:
Prometheus
Also Known As: Me
Postby Xplumberlives » Mon Apr 13, 2009 5:58 pm
That'll teach me to tell you it was used as an engine testbed role similar to the Vulcan! :p
Here are some other images of it in the test role and in anniversary colours.
Postby Saracenman » Mon Apr 13, 2009 6:58 pm
thanks XPL :)
right, this might go quite quickly, it might not - what's the betting SB knows it with his eyes shut? :p
Postby Dan4th » Mon Apr 13, 2009 7:10 pm
Longshot:
Aerocommander?
Postby Saracenman » Mon Apr 13, 2009 7:18 pm
negatorious Danf
Postby Dan4th » Mon Apr 13, 2009 8:38 pm
Well, due to the starboard wing I think I
see out the pilot's window, I think we
may assume it is a JET-powered aircraft.
Two-holer?
Or just really teensy props?
Bizjet of some kind?
Or additional LSD?
Postby Stevieboy » Mon Apr 13, 2009 8:53 pm
Saracenman wrote:thanks XPL :)
Sacre bleu une autre grenouille. ;)
Postby Saracenman » Tue Apr 14, 2009 12:12 am
yep - two engines apparently
looks like SB might already know the answer - surprise surprise =))
Users browsing this forum: No registered users and 21 guests
