Xplumberlives wrote:It is ALWAYS a good read!
Thumper wrote:I use PSP to crop the images, resize for publishing and put on a small frame if I feel like it, it's also handing for removing any dust spots which happens all the time on my Canon Vacuum Cleaner. I don't correct or edit my photo's unless I really want to keep them but they turned out a bit naff. I personally like looking at what I took, not "here's what you could've took"... if that makes sense!
Xplumberlives wrote:Not sure why you suffer with dust so much, I change lenses all the time and ALWAYS make sure that the camera is turned off! This allows the inbuilt cleaning to take place as you turn it off and again when you turn it back on again after removing a lense and refitting the other one! It's a simple procedure to teach yourself!
) what are the best things to use for dust removal from the lens and cleaners etc?
Xplumberlives wrote:Glad the 40D has inbuilt sensor cleaning!!!!!!!!
Mayfly wrote:so has my 450D.....
Stigish wrote:And my 550D
Xplumberlives wrote:Stigish wrote:And my 550D
Do you have little hands too?
Stigish wrote:Xplumberlives wrote:Stigish wrote:And my 550D
Nope, they're well in proportion with my size![]()
On a more miserable note................................I've just had a call from Barclays, whom I start working for on the 5th July...........................to be told I failed pre-employment screening checks!. Basically I failed a credit check, just like the one you have for applying for a loan. Now I'm back to bloody square 1 again, all thanks to my bitch of an ex-missus who nearly bankrupted me ten years ago!
Now this thread should be called 1 step forward...........10 back!
Time for a beer
