Market would be the largest airborne operation in history, delivering over 34,600 men of the 101st, 82nd and 1st Airborne Divisions and the Polish Brigade. 14,589 troops were landed by glider and 20,011 by parachute. Gliders also brought in 1,736 vehicles and 263 artillery pieces. 3,342 tons of ammunition and other supplies were brought by glider and parachute drop.
DT took part in the celebrations in the BBMF Dak most years.
Here's the first of a few I've dug out and will stick on Youtube. Spent some happy hours inside there, listening to Lincs FM on the aircraft radios, while carrying out post installation runs!!! Out test equipment was a bit more modern than the ones in the video though!!
Are their others like this scattered around GB here and there or is this the only one?
As a kid growing up and with a SAC Base in town, the run-ups and takeoffs were bad enough, but the wee hours engine tests on all the B-52s, KC-135s and F-101s were REALLY hard to ignore!
Good to see you, Ron! ANYTHING you care to post on here at any time and on any subject is More than Welcome!
I saw a much shorter clip of that incident, but Wow! And the pilot just nonchalantly lists the events like a drive to the grocery for milk.......
A lot of yours and ours made it home to Limeyland back in WWII that were technically incapable of flight. You have to admire the kind of skill and nerve that takes!
Just goes to show the brilliance of the training the pilots receive & the engineering that goes into these aircraft even if the planes are made with the objective to fly with both wings intact!
As goes the Hush House, at the time, it certainly was the only one of its kind in the UK. Up to that point, the 'pipe' style detuners were the only ones in use, which typically gave a 10-20 db drop in noise, but the 'Hush House' typically gave around a 40+db noise reduction. You could still make out that it was in use, of a night for example, but only as a sort of dull rumble. There were many studies looked at to provide Hush Houses at most RAF bases, but as usual, it didn't come to very much! There are a few more around now, and Coningsby has a new one, built in 2004, across the other side of the airfield from the old one.
Anyhow, enough rambling from me! Here are a couple of recruitment vids for the RAF from the mid - late 70's. As I said, I'll upload a few more to Youtube when time permits!!
