Flight planning...
Re: Flight planning...
Postby Mayfly » Mon Feb 09, 2009 8:26 pm
Ive just tried fs host & it says no sessions found the ip seemed to work tho'
Postby Prometheus » Mon Feb 09, 2009 8:28 pm
Try 67.99.18.212
Wasn't very active last time I tried but give it a whirl
Prometheus
Also Known As: Me
Postby Tom.com » Mon Feb 09, 2009 8:29 pm
got it - how do i use it?
if i have done it right with that ip then there is 1 there but not yours
It now will not let me login
I'm giving up what is the accelerator thing?
Postby Saracenman » Mon Feb 09, 2009 8:35 pm
thanks Prometheus - Wedgy found one too which seems to exist as well - 80.237.155.34
Tom.com - download and install FSHostClient from here - http://www.chocolatesoftware.com/fshost/download.html
once installed, start a single player FSX session (free flight) with a Piper Cub and then start FSHostClient with that IP address - or if that fails use Prometheus' one, but tell me =))
I'm sure you'll figure it out from there - you're a bright lad ;)
Postby Tom.com » Mon Feb 09, 2009 8:36 pm
ok if it dont work im giving up
Postby Saracenman » Mon Feb 09, 2009 8:40 pm
it should work Tom.com - anyway, ignore MY IP address - it doesn't work ~x(
use Prometheus' 67.99.18.212 - you should get a little chatbox come up - on the right you will see "saracenman" - if you right-click on my u/name select "jump to saracenman's location"
sorted :D
oh by the way - you'll all be able to see me, but not Wedgy - he's connected on my LAN so can't see anyone other than me! =))
ps - ignore the Acceleration pack idea - it's extra FSX software
Postby Prometheus » Mon Feb 09, 2009 8:41 pm
These younguns have no patience /:)
Prometheus
Also Known As: Me
Postby Saracenman » Mon Feb 09, 2009 8:48 pm
come on Tom.com - use FSHost mate - it's easy - here's the tutorial - viewtopic.php?f=12&t=27&p=93&hilit=FSHost#p93
Postby Tom.com » Mon Feb 09, 2009 8:51 pm
where do i enter the ip and name?????!?!?!?!?!?! ARGH ~x(
Postby Wedgy » Mon Feb 09, 2009 8:55 pm
In the box for the IP address? :D
There is only 3 boxes ... Player Name, IP Address & Connect port. Put your name and IP in.
Postby Tom.com » Mon Feb 09, 2009 8:58 pm
using 1.1 ive got 1 with 5 players but nothing about iconic
Postby Prometheus » Mon Feb 09, 2009 9:00 pm
Tom it won't mention Iconic, instead you should see something like *Netwings (FSHost 3.2)
Prometheus
Also Known As: Me
Postby Tom.com » Mon Feb 09, 2009 10:26 pm
that was good
we should do that again with more people
Postby Mayfly » Mon Feb 09, 2009 10:46 pm
they beat you up then Tom & make you crash (they do me ) :))
Postby Tom.com » Mon Feb 09, 2009 10:51 pm
it was ok would have been more fun with more people
Postby Mayfly » Mon Feb 09, 2009 10:53 pm
how many of you ?
Postby Tom.com » Mon Feb 09, 2009 10:54 pm
me
wedgy
SM
prometheus
Postby Saracenman » Tue Feb 10, 2009 1:52 am
yeah once we sorted out the buggeration that was GameSpy/FSHost it was fine - as Tom.com says, could have done with a few more souls :p
Prometheus practised his new way to land a Wokka on a carrier though! =))
Postby Prometheus » Tue Feb 10, 2009 7:41 pm
Saracenman wrote:yeah once we sorted out the buggeration that was GameSpy/FSHost it was fine - as Tom.com says, could have done with a few more souls :p
Atleast I landed it...sort of =)) Did you get a screenshot ?
Prometheus
Also Known As: Me
Postby Saracenman » Tue Feb 10, 2009 10:29 pm
sadly not Prometheus - my snapping finger is nowhere near as fast as a nose-diving Chinook! :))
Postby Nickolas » Wed Feb 11, 2009 9:30 pm
Ooooooooooh you lot are harsh. :D :D :D :D
Postby Saracenman » Wed Feb 11, 2009 9:35 pm
tell you what Nickolas - your lad could do with FSX Acceleration to make him compatible with us on multiplayer.
typical Microsoft incompatibility issues X( but well worth it - gives you extra a/c etc and replaces SP2
I'm sure he'd be worthy after he's cleaned the car, done the washing up for a month, mown the lawn, tidied his room and hoovered the house from top to bottom! ;)
Postby Tom.com » Thu Feb 12, 2009 8:55 pm
how much is it?
Postby Saracenman » Thu Feb 12, 2009 11:22 pm
not sure where's best to get it Tom.com, but this will give you a rough idea - not that dear really...
http://www.fspilotshop.com/product_info ... 3godNiiJcQ
Postby Tom.com » Thu Feb 12, 2009 11:23 pm
that is not much, what are the benifits of it?
