Bubbles wrote:Does your little light still flash XP?
RLN wrote:No, neither did I. By the time, I got round to it, it was yukky.
aircraft MSN001
General characteristics
Crew: 3 or 4 (2 pilots, 3rd optional, 1 loadmaster)
Capacity: 37,000 kg (82,000 lb)
116 fully equipped troops / paratroops,
up to 66 stretchers accompanied by 25 medical personnel
Length: 45.1 m (148 ft 0 in)
Wingspan: 42.4 m (139 ft 1 in)
Height: 14.7 m (48 ft 3 in)
Empty weight: 69,853 kg (154,000 lb)
Max takeoff weight: 141,000 kg (310,852 lb)
Max. Landing Weight: 114 tonnes (251,000 lb)
Total Internal Fuel: 50.5 tonnes (111,333 lb)
Powerplant: 4 × EuroProp International TP400-D6[35] turboprop, 8,250 kW (11,060 hp) each
Propellers: 8-bladed, 5.3 m (17 ft 5 in) diameter
Performance
Cruising speed: 780 km/h (480 mph; 420 kn) (Mach 0.68 - 0.72)
Initial Cruise Altitude: at MTOW: 9,000 m (29,000 ft)
Range: 3,298 km (2,049 mi; 1,781 nmi) at max payload (long range cruise speed; reserves as per MIL-C-5011A)
Range at 30-tonne payload: 4,540 km (2,450 nmi)
Range at 20-tonne payload: 6,390 km (3,450 nmi)
Ferry range: 8,710 km (5,412 mi; 4,703 nmi)
Service ceiling: 11,300 m (37,073 ft)
Maximum Operating Altitude: 12,000 m (40,000 ft)
Tactical Takeoff Distance: 980 m (3,215 ft) (aircraft weight 100 tonnes, soft field, ISA, sea level)
Tactical Landing Distance: 770 m (2,526 ft) (as above)
Turning Radius (Ground): 28.6 m
Crew: 3 (two pilots, and one loadmaster are minimum crew)
Capacity:
92 passengers (128 for C-130J-30) or
64 airborne troops (92 for C-130J-30) or
6 pallets (8 pallets for C-130J-30) or
74 litter patients with 2 medical personnel (97 litters for C-130J-30)
2–3 HMMWVs or an M113 armored personnel carrier
Payload: 42,000 lb (19,090 kg) ; for C-130J-30: 44,000 lb/ 19,900 kg
Length: 97 ft 9 in, 29.79 m (for C-130J-30: 112 ft, 9 in, 34.69 m)
Wingspan: 132 ft 7 in (40.41 m)
Height: 38 ft 10 in (11.84 m)
Wing area: 1,745 ft² (162.1 m²)
Empty weight: 75,562 lb (34,274 kg)
Useful load: 72,000 lb (33,000 kg)
Max takeoff weight: up to 175,000 lb (79,378 kg); normal 155,000 lb (70,305 kg)
Powerplant: 4× Rolls-Royce AE 2100D3 turboprop, 4,637 shp (3,458 kW)) each
Propellers: Dowty R391 6-blade composite propeller, 1 per engine
Performance
Maximum speed: 362 knots (417 mph, 671 km/h)
Cruise speed: 348 kn (400 mph, 643 km/h)
Range: 2,835 nmi (3,262 mi, 5,250 km)
Service ceiling: 28,000 ft (8,615 m) with 42,000 pounds (19,090 kilograms) payload
Takeoff distance: 3,127 ft (953 m) at 155,000 lb (70,300 kg) gross weight
Saracenman wrote:now don't be silly SB![]()
it's not as if we sold five Belslows to Heavylift in the late 1970s, only to lease them back for use in the Falklands War, is it?
that would be a silly thing to do!![]()
Mayfly wrote:Saracenman wrote:now don't be silly SB![]()
ermmmm![]()
Za150 wrote:Mayfly wrote:Saracenman wrote:now don't be silly SB![]()
ermmmm![]()
The MOD have never done anything silly before.........
Users browsing this forum: No registered users and 31 guests
