Aviation Jokes
Aviation Jokes
Postby Wedgy » Sun Dec 28, 2008 11:37 am
From the "squawk sheets"
Problem: "Something loose in cockpit."
Solution: "Something tightened in cockpit."
Problem: "Evidence of hydraulic leak on right main landing gear."
Solution: "Evidence removed."
Problem: "Number three engine missing."
Solution: "Engine found on right wing after brief search."
Problem: "DME volume unbelievably loud."
Solution: "Volume set to more believable level."
Problem: Dead bugs on windshield.
Solution: Live bugs on order.
Problem: Autopilot in altitude hold mode produces a 200 fpm descent.
Solution: Cannot reproduce problem on ground.
Problem: IFF inoperative.
Solution: IFF inoperative in OFF mode.
Problem: Friction locks cause throttle levers to stick.
Solution: That's what they're there for.
Problem: "Left inside main tire almost needs replacement."
Solution: "Almost replaced left inside main tire."
Problem: "Test flight OK, except autoland very rough."
Solution: "Autoland not installed on this aircraft."
Problem #1: "#2 Propeller seeping prop fluid."
Solution #1: "#2 Propeller seepage normal."
Problem #2: "#1,#3, and #4 propellers lack normal seepage."
Re: Aviation Jokes
design limits
A stormy flight aboard a Boeing aircraft; an off-duty airline stewardess is sitting next to a man in the grip of serious white-knuckle fever as he watches, through his porthole, the aircraft's wing bending and bouncing in the tempest. The stewardess tries to reassure him; she works in the industry and flies all the time, she tells him. There is nothing to worry about; the pilots have everything under control.
"Madam," he replies, "I am a Boeing engineer and we did not design this aircraft to do what it is doing."
Re: Aviation Jokes
Postby Spitfire » Sun Dec 28, 2008 5:19 pm
There's more engineer reports..........
Pilots: Suspected crack in windshield.
Engineers: Suspect you're right.
Pilots: Number 3 engine missing.
Engineers: Engine found on right wing after brief search.
Pilots: Aircraft handles funny.
Engineers: Aircraft warned to straighten up, fly right, and be serious.
Pilots: Target radar hums
Engineers: Reprogrammed target radar with lyrics.
Pilots: Mouse in cockpit.
Engineers: Cat installed.
Pilot: Noise coming from under instrument panel. Sounds like a midget pounding on something with a hammer.
Engineers: Took hammer away from midget
Re: Aviation Jokes
Postby Mackrick » Sun Dec 28, 2008 8:17 pm
Tower: "Delta 351, you have traffic at 10 o'clock, 6 miles!"
Delta 351: "Give us another hint! We have digital watches!"
"TWA 2341, for noise abatement turn right 45 Degrees."
"Centre, we are at 35,000 feet. How much noise can we make up here?"
"Sir, have you ever heard the noise a 747 makes when it hits a 727?"
From an unknown aircraft waiting in a very long takeoff queue: "I'm f...ing bored!"
Ground Traffic Control: "Last aircraft transmitting, identify yourself immediately!"
Unknown aircraft: "I said I was f... ing bored, not f... ing stupid!"
O'Hare Approach Control to a 747: "United 329 heavy, your traffic is a Fokker,
one o'clock, three miles, Eastbound."
United 239: "Approach, I've always wanted to say this... I've got the little
fokker in sight."
A student became lost during a solo cross-country flight. While attempting to
locate the aircraft on radar, ATC asked, "What was your last known position?"
Student: "When I was number one for takeoff."
