Problems loading?
Having problems with the forums? Have a question? Have a suggestion? Post here
Problems loading?
Postby Mayfly » Mon Feb 06, 2012 8:28 pm
Has anyone had problems loading IA? It has been taking me a while for a couple of days but it seems to be taking longer and longer.....and now only half a page is loading then hanging before loading the rest - I haven't a problem with the other sites
you can see from the photo the scroll bar on the right is down to the bottom ........
Re: Problems loading?
Postby Minty4371 » Mon Feb 06, 2012 8:41 pm
I had a problem loading topics earlier, but it worked OK soon after.
I take that back. Took ages to reload the New Posts page, and then didn't load all of it.
Postby Sooty655 » Mon Feb 06, 2012 8:44 pm
Seems OK for me.
Postby MOD » Mon Feb 06, 2012 9:05 pm
I have had the same issues over the last week or so. I carried out several Broadband speedtests though and found that my 47Mbps connection had dropped to 0.78Mbps. I restarted the BT hub and all was well again. I now have to do this on a daily basis. I am putting off using the BT Broadband helpline because I know my blood pressure will hit record levels..
Postby RLN » Mon Feb 06, 2012 11:25 pm
Couldn't connect at all at 05.15 this morning.
Postby Wedgy » Tue Feb 07, 2012 7:41 am
The only service interruption I can see was early yesterday morning between 05:00 and 06:30.
The server is either connected or not, so puzzled by your issue Mayfly. Minty's post is typical of catching IA when the server is about to go down. Or RLN's post when IA just isn't there (as I noticed myself yesterday morning). But if your issue has been over a matter of days and especially the partial loading of pages, it could be a local issue with your PC (cookies or cache for IA maybe corrupt) - usual tip of clearing these may help :)
Postby Xplumberlives » Tue Feb 07, 2012 8:30 am
Nothing particularly unusual at this end! ;)
Postby Hungry Haggis » Tue Feb 07, 2012 9:30 am
Has been doing that here since Saturday I also thought it was my conection but that is stable @ 7.4Mbps .Had only one similar issue with British Gas but that site always mucks me around anyway.
Postby Hungry Haggis » Thu Feb 09, 2012 11:03 am
uninstalled IE9 other reasons now on IE8 and this loading issue seems to have stopped at least on this laptop wifes 64bit win7 one never got the same issue.mind you I have just done a full reinstall so will see how it works.
Postby Sooty655 » Thu Feb 09, 2012 9:54 pm
IA has been very very slow to load for me this evening. All other websites accessed seem normal, so I don't think it is me/my system. ~x( :(
Postby Xplumberlives » Thu Feb 09, 2012 9:57 pm
Sooty655 wrote:IA has been very very slow to load for me this evening. All other websites accessed seem normal, so I don't think it is me/my system. ~x( :(
I.A. has been slow but F.C. has taken forever! :-o
Postby Dan4th » Fri Feb 10, 2012 1:08 am
Every once in a while IA will either
not let me in or dump me out in the
middle of things but I haven't seen
anything out of the ordinary over the
past few days.........
Even when these minor disruptions
happen, it's never for very long....
So of course, now that I've said THAT.........
I'll see you all in March sometime :D
Postby RLN » Fri Feb 10, 2012 1:31 am
I do occasionally get the forum "hanging" as I go from page to page. When I was dealing with a spammer and moving to and fro between topics, it was hanging quite a bit. Doesn't do it all the time; doesn't seem to be a pattern either.
Return to Forum Support
