PRIVATE MESSAGESThe Private Messaging functions on this forum have been upgraded - so maybe different (and more functional) than other forums you have visited.
Within your Private Messages, there is a menu item labeled "Rules, folders & settings"
As the screenshot shows, within here you are able to create up to 3 custom folders and set rules for private messages as soon as they arrive - just like a standard email client.
Each folder can hold upto 100 private messages, therefore:
Inbox = 100
Outbox = 100
Sent Messages = 100
Custom Folders = 100x3
= 600 private message limit per user.
I will increase/decrease this limit depending on how the SQL database reacts over time.
I would like to take this opportunity to emphasise that all Private messages
ARE PRIVATE, I cannot read them, I can only see stats regarding the number of messages each user currently has.
WARNING:If your inbox reaches 100 messages, you will not receive any new PMs until some messages have been deleted. You will see the following message:
You have 1 private message currently on hold because of full folder.
Release all on-hold messages… they will be re-sorted into the appropriate folder if enough space is made available.
If your "sent" folder reaches 100 messages, each time you send a PM, the oldest message in the folder will be deleted to make room.
