Still keeping super busy however progress on SKP is still going strong. Although the actual build is not progressing at the moment I am sorting out a lot of design and manufacturing issues. I never knew how much work there was in designing a locomotive, there is a lot and this one is VERY complex. Somethings just can't be made in the 1/2" to 1' scale exactly so things have to be redesigned to look the part.
Anyway progress so far,
Boiler design finished (this will look externally almost identical to full size)
Tender chassis design complete
Locomotive chassis design complete
Modifications to my CNC mill to increase accuracy for the build 75% complete
A manufacturing method for the boxpox wheels has also been sorted using 3D CNC
I have even found a way of making the name plates (a challenge in itself!)
These will be water slide transfers onto brass backing and the name will be chemically etched onto brass
This is to scale 33.45mm high
And how big it looks against the frame
And the tender axle boxes and springs (which are to be hidden in the leaf Spring castings)
