Dougs wrote:yes i have done a couple in the past i did XM575 and XM655 bit tricky as the formats are odd for the iris vulc
update; i have spent the day finishing off the air brakes so i can post the video later on
Dan4th wrote:Now I remember.....
Didn't the aircraft exceed specified
limits in some way at the hands of
a test pilot?
Wouldn't be the first time!
Dougs wrote:That was the original story ..... However turns out it was not the pilots fault and the wing had a known flaw that had been previously reported took 50+years for the truth to come out tho
Nickolas wrote:Did you ignore the controller screaming 'Go around'??
Dougs wrote:Nickolas wrote:Did you ignore the controller screaming 'Go around'??
Couldn't hear them too noisy screaming my head off.
Sooty thought it was you that was researching the loss of vx770 i have to say i am in the not guilty camp he didnt look to be doing anything out of the ordinary and was very experienced
Dougs wrote:I have been a busy boy and got my software up and running again so i have been able to work on VX770 and get it up to scratch as i havent worked on it for ages i decided to do flight sim 2004 as it is way easier to work with once the model is finished i will probably hae a crack at FSX again
anyway this is what she looks like now
one of the best things is what i have found in the reserch i have had to do which has all gone to shape it correctly;
the nose leg is smaller
the airframe is very slightly shorter
the wing has elevators and airelons (pls for give the spelling)not elevons
the airbrakes are 'backwards' and has two at the bottom not one
and many many more diferances between VX770 and B1 vulcans
