Iris Vulcan XM655 and XM575
Postby Dougs » Sat May 23, 2009 9:11 pm
been busy with my airbrush again and made some repaints for the FSX iris vulcan and my fave vulc's
XM655
and XM575
can supply the files to anyone interested
Re: iris vulcan XM655 and XM575
Postby Saracenman » Sat May 23, 2009 9:16 pm
sorry Dougs - what's the difference between yours and the original Iris version?
i haven't opened FSX to look, so it's probably bleedin' obvious and I'm a complete twat! :p
Re: Iris Vulcan XM655 and XM575
Postby Dougs » Sat May 23, 2009 9:21 pm
same plane but i have repainted the tail numbers sorry the pictures are not very big so they dont show up too well
just working on a resize! :o)
now that should be better the tail numbers I did were not availible on the original software but i had to do an old XM655 livery as she now has the red grayhounds not 101 sqd.
Postby Bovril » Sat May 23, 2009 9:26 pm
she currently in 50 sqd not 101 :D
Postby Dougs » Sat May 23, 2009 9:28 pm
sorry bovril the grayhounds are a work in progress, i have a wife sized monkey on my back at the mo so i will get round to it later :ymblushing: ~x(
Postby Mayfly » Sat May 23, 2009 10:10 pm
what programme do you use - FSX repaint?
Postby Dougs » Sun May 24, 2009 8:49 am
hi mrs T
no i have found the abacus software to be a bit 'buggy' with vista so I use DDS converter 2 to chainge the files to bmp or jpg and then edit with paintshop pro or paint. but the disadvantage I have noticed is a small reduction in quality through the conversion process. it was much easyier with flight sim 9, but i will figure it out eventually may even try and convert my two aircraft to fsx (Avro Atlantic & Vulcan B3) when i can figure it all out just cant get the time at the moment, and it takes soooooo long :)
Re: Iris Vulcan XM655 and XM575 +50 sqd xm655
Postby Dougs » Sun May 24, 2009 11:47 pm
have done it! 50 sqd. update
still having problems with pic quality after conversion though but i will figure it out eventually
Postby Wedgy » Sun May 24, 2009 11:59 pm
At first glance, the picture quality doesn't look bad at all ... would be interesting to see side by side ;)
:ymapplause:
Postby Dougs » Mon May 25, 2009 10:27 am
ok here is the side by side comparison i anyone knows how to fix this i would be forever great full the picture quality looks fine in the original so it must be something to do with layers but i don't know enough about it all yet, i will have to get my mortarboard out and get studying
Postby Mayfly » Mon May 25, 2009 11:28 am
as you are using paint or psp are you 'drawing' the text or are you using the text tool to 'write' the text?
bum haven't made myself very clear.... :ymblushing:
Postby Jigsaw » Mon May 25, 2009 1:55 pm
Never mind Pam, at least you tried to help and did not give him the bums rush.
All may become clear once he has read the associated BUMf.
Or he may just go BUMbling along like a country BUMkin BUMping into and getting stung on the BUM by BUMblebees :D
Postby Dougs » Mon May 25, 2009 8:42 pm
I understand you prefectly Pam I did draw the text not the text tools the two pictures look identical quality
i am looking it up but it has something to do with the alpha layer (reflections layer) dont want to be a BUM and bore anyone with the details ~x( i will 'BOTTOM' it though ;) :p
the original;
my repaint;
Postby Tom.com » Tue May 26, 2009 6:31 pm
did you write it on there or copy it onto there?
Postby Dougs » Tue May 26, 2009 8:49 pm
well Tom.com bit of free hand bit of cutting and pasteing and some patching up would sum up my latest 'effort'
repaints are not my forte, enjoy making the models more, like my avro atlantic and B3 vulcan unfortunately both are for fs9 and i have upgraded so i have to start again and it takes me about 1 1/2 months to get one right and i will have to learn it all again for FSX. :((
Postby Tom.com » Thu May 28, 2009 10:42 am
well when you copy there is a high chance that you can have size problems so it might be better if you did it straight on to it.
Postby Jigsaw » Thu May 28, 2009 6:18 pm
Tom.com wrote:well when you copy there is a high chance that you can have size problems so it might be better if you did it straight on to it.
Now I have my excuse, cheers T.C :D
Postby Dougs » Fri May 29, 2009 12:27 pm
size problems! :ymblushing:
have you been talking to my wife? :))
Postby Bovril » Tue Jul 13, 2010 10:53 pm
:D :D :D :D :D
sat on runway 05, Wellesbourne, ready to taxi
Postby Dougs » Wed Jul 14, 2010 7:50 am
:D :D :D :D nice!!! did you repaint? fantastic quality paint job
Postby Roving » Thu Apr 28, 2011 2:48 pm
Hi,
Dougs, would you be able to e-mail me the files for those re-skins? My e-mail is vulcanxj823ATgmailDOTCOM. Cheers,
Henry
P.S. Bovrill, would you be able send me your files as well maybe? Cheers :)
Roving
Also Known As: Henry Kelsall
Postby Dougs » Fri Apr 29, 2011 7:32 pm
Hi sorry I don't have the files any more I had to stop playing a year ago and have had a new pc since so have lost nearly all my repaints and aircraft :(
Postby Roving » Sat Apr 30, 2011 11:22 am
Dam. Ah well can't be helped, thanks for the reply by the way. Just that Ive been after some repaints for the model for a while.
Roving
